Cx5 turbo
Old Nov 11, 2018 | 08:38 PM
  #21
schmieg's Avatar
The other thing to remember with turbo charged engines is that they usually require a higher octane gasoline.
I think that if I need to tow something, I will use my Grand Cherokee.
Old Nov 12, 2018 | 06:50 AM
  #22
MrBillMazda's Avatar
Maybe 'usually' is correct, but the following may be also:
Old Nov 12, 2018 | 11:13 AM
  #23
schmieg's Avatar
Originally Posted by MrBillMazda
Maybe 'usually' is correct, but the following may be also: https://www.youtube.com/watch?v=oxr9Dyv778U
The CR advice is good advice, but the higher compression involved with turbo and super charging almost always results in a requirement for higher octane fuel.
Old Nov 12, 2018 | 11:20 AM
  #24
paris1's Avatar
AND...if there is an "either/or" option (such as with the Mazda 2.5T), it's because the engine employs a knock sensor which will advance the timing when premium is used which results in increased horsepower. As always, you have to take anything automotive in C/R with a grain of salt!
Old Nov 12, 2018 | 11:25 AM
  #25
schmieg's Avatar
You sound like you are anxious to blow a forced injection engine to save money on gas. I will use whatever fuel is required for a particular engine and, depending on the use of the vehicle, I will possibly use the fuel recommended for a particular engine.
I will say that if you burn up a forced injection engine that calls for 91 octane and they find you have 87 in the tank, your warranty will be void.
Old Nov 12, 2018 | 11:30 AM
  #26
I just located this from Car and Driver: The new engine is the biggest change, and it's the same turbocharged 2.5-liter four-cylinder found in the Mazda CX-9 three-row crossover and the Mazda 6 mid-size sedan. In the CX-5, it makes 250 horsepower and 310 lb-ft of torque (that's if you use premium fuel; as with those other models, Mazda quotes a lower output of 227 hp on regular gasoline). It'll be available on higher trim levels paired with a six-speed automatic transmission, and we presume it will be available as both front- and all-wheel drive. The base naturally aspirated four-cylinder engine should carry over into 2019 without any changes.
Old Nov 12, 2018 | 11:35 AM
  #27
schmieg's Avatar
That will be a peppy, little machine. I like that they have designed the option for regular or premium into the system. You can then use regular for normal stuff and load a tank of premium if you want to be stupid or need towing capability.
Old Nov 12, 2018 | 12:08 PM
  #28
paris1's Avatar
That's exactly the point I was trying to make in #24 above. Your response in #25 makes no sense.
Old Nov 12, 2018 | 12:20 PM
  #29
schmieg's Avatar
It makes perfect sense if the system isn't designed to use different grades of fuel. Many are not designed that way and using lower octane fuel in those FI engines can be catastrophic.
Old Nov 12, 2018 | 04:49 PM
  #30
Originally Posted by mazda_nc_dude
In my case, the non-turbo has enough power. I am not willing to pay more for gas and the vehicle to get the power of the 2.5 liter turbo. What would have made sense for the CX-5 is to go with a 2.0 liter turbo, but I assume they just said we already have the 2.5 liter turbo, why develop a new engine.
Looking at all other brands (including luxury and non-luxury), the 2.0 liter turbo is the sweet spot for both power and mpg values.
I commend yo for your choice. I don't drive that much to warrant not purchasing what I want.
