CX5 Import - Help!
Old Jan 10, 2023 | 03:23 PM
mike51's Avatar
Originally Posted by greg.kolev
Hi Mike
Did you manage to solve your issue? I have a similar one
Not yet - I have until around March as allowed 6 months after driving it.
There are videos on youtube explaining how to remove the rear bumper. It doesn't look difficult to me. So I plan to do that and examine the fog lights. Then buy appropriate automotive cable and any required fog light parts (also available used on ebay) if I can't just move the interior fitting from one to the other.
The headlights could prove a much bigger issue. The manual says you can drive "temporarily" in a country that drives on the opposite side of the road from how the headlights are. Certainly there is only a small "kick up" so I'm hoping it might just pass as is. If not, new light units seem to cost around £550 but all the ones I've seen online (at UK online stores mostly) say "for driving on the right" - i.e. the opposite of the UK system. A bit crazy and not sure what I'll do there.
What is your situation? Are you making any progress in any of these areas?
Old Nov 13, 2025 | 06:33 AM
heroicsatsuma's Avatar
Hey,
Sorry to jump on an old thread, but I have the exact same issues in the opposite direction.
I have had a look at the rear fog lamps and only one side has the hole cut out to receive a bulb, so not as easy as just moving the wires over to the other side. I was thinking maybe to buy an EU rear fog lamp, so I can have 2 rear fog light (should look nice), but how on Earth can I wire it up? Can I just splice into the existing rear fog light wiring? Will there be enough voltage to power both?
Also on the headlight situation I found that it maybe possible to adjust the AFS ECU from RHD to LHD - that maybe be bs though waiting on Mazda to confirm.
Importing is a right pain!
Old Nov 13, 2025 | 08:41 AM
mike51's Avatar
I've got my car registered now and yes I agree importing is very difficult. In fact, its so difficult and time-consuming they make it very, very hard to do the right thing. Even when its done you have the question of "should I go to a "specialist" insurer who will charge 4x the regular price or should I just call it a Mazda CX-5 SE-L when I know it was a Mazda CX-5 <some other name>
I just wanted the minimum to pass and didn't care about both fog lights on at the same time. So from memory I spliced in a new cable and ran it along the rear from one fog light to the other. I made sure the previous fog light was switched off to avoid any current issues. Maybe someone else knows if it would be fine to run two.
Old Jan 19, 2026 | 03:01 AM
I gave up - couldn't find EU spec headlights with AFS - just drove if back to the UK hopefully someone wants to buy it else those thiefs at webuyanycar are going to give me peanuts. I really liked that motor oh well :/
Elena Gonzalez
Aug 10, 2010 06:42 PM
wiseman82
Jan 27, 2010 09:38 PM
caines
Jul 3, 2008 12:08 PM
dw78
Apr 22, 2007 09:33 AM
gurubob
Jun 12, 2005 04:34 AM
