CX-5 Oil warning light
Hi,
Need advice on an issue with our CX-5 - It's an 2015 2.2 Diesel (175 HP).
Bought it new and now it has 60.000 km on the meter.
Always followed the service plan and all scheduled maintenance being done.
Now to the problem :-)
Last week the oil pressure waring light came on. Called the garage and they recommended towing to the garage to avoid any potential damage.
After checking the car they claimed that it only needed a regular service and nothing else. Fair enough, but it seems quite awkward to have the car towed for that
. Previous maintenace done less than 18.000 km ago...
I asked if that´s what I can expect in the future but they explained that the software was upgraded and this kind of problems would be “less frequent” in the future.
Q1: Is this related to the diesel & oil problem discussed in this forum?
Q2: Oil quality – the garage is using Mobil1 (5W-40) unknown spec but they promised to get back to me with the exact oil used – any ideas of what´s the best oil to use?
BR
HåkanW
. Previous maintenace done less than 18.000 km ago...I asked if that´s what I can expect in the future but they explained that the software was upgraded and this kind of problems would be “less frequent” in the future.
BR
HåkanW
Hi,
Checked the oil when warning light came on - Level OK , in the middle between min and max.
According to the Owners manual (Sweden) it should be Mazda Original Oil Supra DPF 0W-30 or Mazda Original Oil Ultra DPF 5W-30.
Any ideas about service interval - manual says 20.000 km intervals.
Maybe too long?
NR
Håkan
Maybe too long?
NR
Håkan
And here we go again
Same warning light came on again - car been driven less than 100 km since last time. Towed back to the garage again. Sadly there is only one "authorized" Mazda dealer/garage in this area...
Will see what they will come up with now. Apparently they only fixed the symptoms last time, not the problem
BR
HåkanW
BR
HåkanW
There is a Tech Bulletin out for your problem, the cause being a PCM software issue.
I've also seen issues with faulty Oil pressure sensors.
Hopefully they get it fixed quickly for you.
Hi,
Thanks for the info. Just picked up my car and got the same information - software updated again and the problem is supposed to be fixed.
Well - that´s probably what we are supposed to accept when buying new cars nowadays - if the car is indicating malfunctions fix it with new software
BR
HåkanW
BR
HåkanW
Hi,
BR
HåkanW
BR
HåkanW
