Cx 5 oil consumption
Well, I went to the dealer yesterday to "start" the process of the oil consumption issue..pay for an oil change, they check the dipstick, you return 1000 miles later, check the dipstick ...etc.
Called Mazda Corporate this AM , explained my problem and the above TSB, the customer care rep put me on hold to look up the TSB, he read it and said that this oil change I have coming up should be free and any make up oil should also be free until Mazda comes up with a solution. He also told me that I should notify the dealer about this TSB as it is less than a month old.
Rep was a good guy
I notified the dealer and after I read the service writer the TSB, too lazy to look it up I guess, he says,, well your check engine light didnt come on and he would have the tech look it up when I come in.
So this is where I stand.....update next week.
Thanks for all the help and m5xguy for posting the TSB.
Rep was a good guy
UPDATE....After much discussion with Mazda customer service, I was sent an eGiftCard that basically covered my oil charge that was originally booked to start the oil consumption monitoring process. My car did throw a code P250F. This low oil code must of verified my original concern with the dealer. This oil changed was going to be paid for by me, but Mazda stepped up.
So where do I stand...if my oil light returns, I am to bring my car to a Mazda dealer to have them add a quart per the TSB...even if I am local, I drive 13 miles to the dealer...fail Mazda
If this happens 400 miles from home I am to contact the local Mazda dealer to have him add a quart of oil.....another fail Mazda
If this should happen at night, I get a room and call the Mazda dealer in the morning...major fail Mazda
So now I wait until the oil light comes back on and pray I am home.
Of course I will be checking the oil every couple of hundred miles.
People if your following this thread and your car falls with in the VIN s above, call your dealer/Mazda corporate and start complaining.
...and as the TSB states, there is no current fix.
Thanks to all that helped.
My son's 21 Carbon Edition (Turbo) is also having the same problem . My 2018 Honda Turbo had this problem but that was in cold regions only I never had hte probem in Florida. (Honda extended the engine warranty)
My son's Mazda is in Miami and having this problem. I read the problem is Valve Seals. Hope they have a recall to fix the problem.
How strange for a motor so far into its life cycle to suddenly start having this issue. I was just starting to relax knowing I had a '21 after reading the coolant leak thread and now we have this to worry about BECAUSE I have a '21. Great...
What is really disconcerting is from what the TSB states, Mazda has no idea what it causing the issue so you are basically driving around with a defective motor until they figure it out. How do they know for sure the motor isn't being damaged while this goes on if they don't know the origin of the leak?
... do they know for sure the motor isn't being damaged while this goes on if they don't know the origin of the leak?
I can't imagine Mazda doing a mass engine repair/replace recall on all of the affected VINs, but I guess it's possible if the stem seal problem is widespread. So if they don't do a repair recall on yours, then you'll have to just keep checking the oil level regularly forever (which should be done anyway), and hope that Mazda provides extended warranty coverage, so you don't have to worry about this problem kicking in out of warranty, many thousands of miles down the road (assuming you plan on keeping it beyond the normal warranty). This is looking like a really unhappy situation for the owners of these vehicles.
Not sure if everyone is aware of this but certain Mazda and Honda engines have a known issue with low oil light.
It seems the amount of oil per engine varies not only on engine model but individual units as well.
Engine models vary from 4.8 to 5.1 quarts.
My 2020 CX-5 states 4.8 quarts but requires an additional 1/2 quart or the low engine light will come on after about 1000 miles.
I checked with other local owners some are fine with the manufacturer amount and others needed to add oil.
Some less than I did and some more.
I've verified this "phenomena" with several mechanics I know.
I now just add an additional 1/2 quart when I change oil.
I have had no issues since; the oil level remains steady; the engine does not burn or leak oil.
Given what Mazda said in the TSB, I'd be checking the oil level every 200 miles if I had one of the impacted vehicles. Yes.that's a real PITA, but it's also the only way to catch this problem early, and hopefully minimize the damage. And if the level starts dropping significantly, you should then contact your dealership in order to get the problem registered with them, and get a consumption test going (or whatever action they choose to take). And in case you're not aware, always wait 5 minutes or longer after the engine is shut off, before checking the oil level in these vehicles.
We bought a 2020 MAZDA CX-5 & a 2020 MAZDA 3 (daughter) in Nov 2020. I do the oil changes and follow the book. I am very concerned about the loss of oil between changes. These are our first MAZDAs and this should not be happening on new vehicles. A random check on the CX-5 showed a very low reading about half-way through one cycle and the oil light came on with about 6500 miles on a recent cycle. I just did the 3 & my daughter got the oil light at 100 miles. Have you found out anything significant about oil loss in these vehicles. I don't like this. It shouldn't be happening. I never have to look at my 300k mile, 07 Corolla between changes. A 1/2 quart puts the level where it needs to be. I think I want to contact the dealer and make this a matter of record.
That said, I'll ask which engine your vehicles have, and also (exactly) how much oil you used to refill both of them on your most recent oil changes.
