CX-5 Cylinder Deactivation Operation
I have a 2023 CX-5 regular engine.
Question about when this functionality is supposed to happen. I would guess engine would reduce from 4 to 2 cylinders when driver is cruising, perhaps on hwy using cruise control. However, when i turn on the dash screen monitor to show the status of the feature (Information > Fuel Efficiency ...), I see the status symbol indicating a change from 4 to 2 and back to 4 repeatedly while driving in city. It seems to deactivate/reactivate much too often. Anyone have input to share on when theirs deactivates? I hope this is NOT a malfunction.
Thanks all
Thanks all
Thanks all
Thanks all
I don't think CD is discontinued. I was just offered a 2025 Mazda CX-5 GS CD AWD 6AT last week to replace my 2019 CX5 CD. I didn't notice any difference driving my 2019 CD but I only get 600 km per 47L fill up ( 373 miles per 12.4 US Gallon fill up) How are you getting 600 Miles?
On my 2022 CD is totally smooth and seamless. If monitoring I can also see it switch back and forth from 4 to 2 and back to 4 sometimes as it decides how it wants to proceed. If I tap the accelerator when using 2 the switch back to 4 is never noticeable.
That's still happening. At my local Mazda dealer it's about a 80/20 split on the 2025s. Of the cars on lot or in transit 12 of them have cylinder deactivation, 4 of them do not have CD according to the online window stickers.
I'm a new Mazda owner of two 2022 CX-5 Premiums and so far I'm quite impressed.
So as long as we're on the CD discussion, I noticed that my cylinder deactivation monitor screen will go from 4 active to 2 active and then 0 active. In other words, all the cylinders in the graphic go dark. That would indicate that none are active. But how is this possible? Does the transmission torque converter keep the engine spinning even though there's no combustion happening? As soon as I touch the gas pedal, all four cylinders light up again.
Thanks!
Thanks!
Since the pistons are still working when deactivation occurs, I have to conclude that the valves are held open otherwise there would be an effect similar to a jake brake.
However, in the Mazda blurb and videos, they show that the lifters are deactivated and the valves stay shut.
Wouldn't the pistons be acting similar to an air compressor and thus using energy from the engine to compress the trapped air?
I need to do more research to figure this out.
