CX-5 auto trans fluid change
How often do you change the auto trans fluid, and what kind do you recommend?
My 2017 CX-5 owner's manual does not list a change interval for the auto trans fluid. It does specify intervals and fluids for the differentials and the transfer case.
I'm not a fan of "lifetime" fluids.
Thanks for the help.
Mazda Original Oil ATF-FZ
A service advisor at the dealership told me "Lifetime" but 100,000mi is what they recommend when I had mine changed at 35.000mi. (Florida heat is hard on automatic transmissions).
He reminded me that I have a lifetime dealership drivetrain warranty and not to worry about it but I had it done anyway.
My fixit guy (Cappello's in Ossining, NY) insisted that he change all fluids at 100,000
He's kept the car in tip top shape at minimum dollars for years so I trust this advice
the only thing he can't prevent is people texting and rear ending me ( 3 times in the past 4 years, last one was the worst, almost totaled that car)
Damn 3 accidents that sucks. Let's hope and wish that you have a safe 2020.
We now live in South East Florida and it is by far the worst drivers I have ever seen. I might look into buying a TANK .
Happy New Year and be safe.
Jim
Jim
Not a fan of "lifetime" fluids either. Drained and filled the rear differential oil in my last vehicle (because it's so easy to access) at 35,000 miles and it was filthy. Also later replaced the brake fluid and power steering fluid, and the transfer case and front differential. Nice thing with EPS is it's one less fluid to change, and the EPS is one of the strengths of this car. Replacing the factory fills is good long term maintenance.
I used to think this was the case, but they have test strips to check the fluid and I have had shops tell me there was no need to change it when I specifically came in for a fluid change on my '11 Tacoma. They checked it and said I was good to go. Now has 90k miles and is on the original fluid. Just had the original ATM fluid changed today.
