CX 5 2.2 d 2014 cluster
Old Oct 28, 2024 | 08:07 AM
Elviskavaz's Avatar
Default CX 5 2.2 d 2014 cluster
Hello.
My name is Elvis and I am from Bosnia and Herzegovina. I have Mazda CX-5 2.2 d 2014. Recently I bought this car. And I noticed that speedometer or cluster is not showing correct speed. Also when I turn off car needle that shows speed sometimes jumps or it moves to 80 Kmh or 140 kmh. And stays there. So I went to a guy to fix this. And he fixed speed so it shows fair enough correct speed. But still needle jumps when I turn off the car or it stays on any other speed. And when I start a car it doesn't want to return needle for showing a speed to zero. So I decided to change cluster and I got one. I know how to remove and install new one. But when I installed new one it shows a DTC U2300 and it doesn't have options like old one. Did anyone had the same problem or does someone know what to do with this?
Thank you for help.
Old Oct 28, 2024 | 11:42 AM
A DTC U2300 is an error code for the electronic brake system.
Can't say for sure, but you can get all kinds of code issues if didn't disconnect/reconnect the battery correctly when replaced the cluster, or anything which is hooked to the ECU/ECM/PCM (vehicle computer).
If you are not familiar and or don't have the proper equipment to find the reason for the code, you should take it to a certified technician who can.
Otherwise, you may cost yourself more time and money trying to attempt it yourself.
Old Oct 28, 2024 | 03:05 PM
Mazdaon's Avatar
Elvis, the instrument cluster stores the VIN number and as-built data from the donor car, all car configurations and options are here. Hence, the U2300 error.
Don't expect it to work as-is, it needs to be programmed into your car. You need a scanner to handle as-built data or get free Forscan and ELM327.
First you need to store data from your car's IC and save it to the computer, install donor cluster and write this data.
Old Oct 29, 2024 | 02:48 AM
Elviskavaz's Avatar
Thank you for information. I have Forscan and ELM237. Can you please tell me how to do that. Because I called Mazda service and they want 2000 euros to do this. I mean it is really expensive. And this would be first time to do something like that.
Old Oct 29, 2024 | 11:05 AM
Mazdaon's Avatar
I don't have the time right now, but I'll Private Message the instructions.
Old Oct 29, 2024 | 01:57 PM
schmieg's Avatar
Is there a restriction on receiving and sending PM's on this forum? Some require a minimum number of posts and the OP only has 2 at this moment.
Old Oct 29, 2024 | 05:58 PM
Elviskavaz's Avatar
Thank you very much for that. I appreciate a lot
AG16
Aug 14, 2024 02:06 PM
TromboneJoe
Aug 10, 2024 11:01 AM
JM16601
May 12, 2024 06:44 AM
cimeron
Feb 19, 2020 11:54 AM
