Climate control mode buttons
Old Dec 5, 2019 | 11:58 AM
Leftys7's Avatar
Question Climate control mode buttons
The buttons that change which vents the air comes through. Can anyone explain why there are two? The owners manual doesn't. Is there any difference between the two?
Old Dec 5, 2019 | 02:21 PM
3carmonte's Avatar
With no year or model info...Is this the system you have? https://owners-manual.mazda.com/gen/.../06010400.html
Old Dec 5, 2019 | 04:44 PM
Leftys7's Avatar
2016.5 GT,
Actually not exactly the same one. My button on the left says "mode" with a triangle pointing left. My right button has a seated figure with no words and a triangle pointing right.
Thanks for your post. Ha, figured it out. Rotates to vent settings in different directions. Big deal.
Old Dec 5, 2019 | 08:05 PM
3carmonte's Avatar
Ah. This one. https://www.mazdausa.com/static/manu.../06010400.html
Which when depressed, takes you through these...https://www.mazdausa.com/static/manu.../06010202.html
My 2014-T has a multi-position dial for this function. Fancy it's not. Functional it is.
Old Dec 5, 2019 | 08:28 PM
Leftys7's Avatar
Smile Buttons
Yes, That's the one. No need to duplicate the functions to my mind and why label them differently? The other example at least makes sense.
Old Dec 6, 2019 | 07:27 AM
3carmonte's Avatar
Re: "My right button has a seated figure with no words and a triangle pointing right".
Does pressing the right arrow and then the left arrow bring you back to the vent selection you were at before you pressed the right arrow? IE: "Clockwise/counterclockwise" function? I still don't get the seat on the RH button. I looked in the explanation of seats and it's not for any adjustment or heater selection.
Old Dec 6, 2019 | 10:06 AM
Leftys7's Avatar
I know, I could find nothing when I looked at the manual. It is as you say (and as the other dash makes clearer, One is clockwise, the other cclockwise). A meaningless, from a practical point of view, duplication.
Old Dec 7, 2019 | 08:51 AM
Conrad 16.5's Avatar
You have the dual climate control system. The mode button on the right with the triangle is for the passenger side adjustment, when the system is set for independent adjustment, of the air selection source.
Old Dec 7, 2019 | 09:51 AM
Leftys7's Avatar
Talking
Nice, that's what I'd hoped at one point but it didn't seem to do anything differently. I'll check it out. Thanks!
NOPE, tried it . Both do the same, control both sides (that is, there is only "one side": all of the vents).
Old Dec 8, 2019 | 08:24 AM
Did you set the system to work in dual mode?
