Any way to turn off CX-5 Signature 2023 DRLs?
Old Apr 15, 2024 | 04:56 PM
noeffort's Avatar
Default Any way to turn off CX-5 Signature 2023 DRLs?
Any Mazda techs here? Trying to turn off my DRL's, PITA that headlights are on with halos. I was going to pull the DRL relay but there isn't one! Is there any software or other method to turn them off.
Any info would be greatly appreciated.
Old Apr 16, 2024 | 11:45 AM
Alexmed2002's Avatar
Is there a specific reason you're trying to disable them? If you are parked and turn on the parking brake (E-Brake), it will turn the DRL lights off. The car also turns them off in traffic when you are stopped after a few seconds and turns them back on once you are moving again.
Old Apr 16, 2024 | 11:53 AM
noeffort's Avatar
If halos were only on I wouldn't mind. Dam headlights cost a fortune to replace from what I have read. if it was the case of just replacing a bulb when needed I wouldn't mind.
Old Apr 16, 2024 | 11:59 AM
The DRLs can look like the headlights are on due to their brightness, but the headlights should only actually be turned on if you manually do it with the switch or if you leave it on auto and the car detects that it's dark out.
Old Apr 16, 2024 | 12:19 PM
noeffort's Avatar
Thanks, I will have my wife look when I have car in motion. I'm looking at reflection in garage and it may only be the DRL'S.
Old Apr 16, 2024 | 02:55 PM
noeffort's Avatar
Confirmed headlight is on when in "off" or "auto" position when daytime driving.
Old Aug 20, 2024 | 01:41 AM
AdamBomb's Avatar
I'm not sure if the Signature trim applies, but on certain models it can be found here:
Settings → Vehicle Settings → Exterior Lighting → Daytime Running Lights → Enable, Disable
diehard888
Apr 12, 2023 06:54 AM
Larry Bushey
Mar 28, 2021 09:33 PM
mikeynavy
Mar 1, 2020 09:55 PM
Nicole Snodgrass
Mar 19, 2018 02:03 PM
mharris6165
Jul 1, 2014 05:43 AM
