ABS Errors from scanner, but no dash light
Old Dec 4, 2023 | 08:36 AM
Jat007's Avatar
Question ABS Errors from scanner, but no dash light
Greetings,
According to my mechanic, while he's scanning for door locks issues, he came across 3 errors for my ABS system. However, I have no ABS or any CEL lights on my dash. The braking performance hasn't changed one bit since I bought it with 48K miles and now has 107K miles. I did get new brake rotors and pads last year, I assume there are 4 ABS sensor (one per wheel), is that mean I have 3 bad sensors out of 3 then?
Thanks in advance.
Jat
Old Dec 4, 2023 | 10:42 AM
Alexmed2002's Avatar
Those codes are probably from when you had your pads + rotors replaced. That's normal when your car is put in maintainence mode. If you're not getting any lights on the dashboard and the car is performing fine, I wouldn't worry about it. Your mechanic should try resetting the codes to see if they come back. If they stick and reveal themselves again, then that's when you should be having the sensors checked and replaced.
Old Dec 4, 2023 | 11:23 AM
Jat007's Avatar
Thank you, Alexmed2002!!
90-B2200
Mar 6, 2023 05:45 AM
90-B2200
Jan 17, 2023 09:06 PM
skyrider
Dec 29, 2022 05:47 AM
fixit007
Apr 25, 2021 07:46 PM
Coach-daddy
Jan 12, 2012 01:58 PM
