Abs
Exactly how do the ABS on a 1990 B2200 work? What are the components, electrical and mechanical? How do they detect brake locking and how do they react to prevent it?
We are diagnosing the ABS light and brake lights illuminated on the dash.
Also, there is a scraping noise that sounds like it might be coming from the right rear wheel area, perhaps inside the drum.
Well, I’m not sure we can access that info actually. It engine is the original 2.2 (rebuilt) but it has Weber swap and the computer in the kick panel is not currently installed. Can we access abs DTC’s without it?
You can use the other side brake as a mirror image.
The scraping like noise turned out to be the driveshaft carrier bearing. I’m glad to discover this since it’s not a big deal. We confirmed it by putting the rear up on jack stands and running it in gear to zero on on where the noise was coming from.
Great investigative work !
