6th gear
Old Oct 6, 2024 | 04:39 AM
padger's Avatar
Default 6th gear
HI all
I have a 2012 cx5 with 88000 miles on the clock and runs like a dream. but recentlry when in 6th gear the gear stick starts to vibrate it keeps popping out into neutral....
any ideas ??
thanks
Old Oct 7, 2024 | 05:01 AM
Check for worn engine & transmission mounts.
Old Oct 7, 2024 | 05:14 AM
padger's Avatar
hi.
thanks for the info. would that just affect 6th gear or all of them??
Old Oct 7, 2024 | 06:35 AM
Depending on the problem, it can start affecting only one gear and then the rest.
Old Oct 7, 2024 | 07:15 AM
padger's Avatar
the engine/transmission mounts or the issue with jumping into neutral??
Old Oct 7, 2024 | 07:29 AM
Jumping into neutral which is your issue I am answering you about.
Loose engine or transmission mounts are what can cause that issue.
If they get loose enough the issue can progress to any gear you are in, if your hand is not on the shifter.
Check and make sure all bolts are all there, none missing, and tightened properly.
If that doesn't solve your issue than you will need to look at other causes (broken motor mount, worn shifter, transmission, etc.)
Old Oct 7, 2024 | 07:47 AM
padger's Avatar
Many thanks, it's booked in with a gearbox place in the morning, fingers crossed it's a mount or loose bolt then🤞🤞👍👍
Old Oct 7, 2024 | 04:28 PM
padger's Avatar
hi
ive read on another group that someone had the exact same issue im having, changed the transmission oil and bingo, sorted,,,,, does that sound viable??
Old Oct 9, 2024 | 03:49 PM
hi
Yes, that is possible but requires dropping the transmission pan to change the filter to accomplish.
I would not change the fluid without changing the filter.
Old Oct 10, 2024 | 06:08 AM
Lobstah, this person has a manual gearbox, not a auto.
