2023 signature oil dirty
Old Feb 3, 2025 | 04:17 PM
  #21
Originally Posted by IMAOLDSCHOOL1FAIL[color=#c0392b
]This sounds normal - for a turbo which in effect uses the engine oil to cool the turbo- thus engine oil goes thru the turbo which gets very hot and desecrates the oil more rapidly than non-turbo combustion engines. If you are spooling the turbo frequently and drive aggressively it can shorthen oil life quickly --- If you treat your vehicle well , allowing turbo cool down after spirited driving and perform frequent oil/filter changes -you should be fine - I wouldnt be concerned about blow-by or oil leaking past the rings with this young of an engine. If you see a loss of a quart after low mileage ( 3000 ) oil changes - then you may have cause to be concerned - Keep performing the engine oil / filter service - There appears to be a few people on the net that like taking shots at Mazda and exaggerating reports of burning oil in these high compression skyactive engines at low mileage -- If you break it in correctly you should have no issues as these engines are what make Mazdas great - Theres a few others in here going off topic into transmission services - which I will not reply to because it creates confusion and is why we try to stay on topic --in this case - dirty engine oil - Remember Mazda dropped the compression in the turbos 10:1 from 13:1 usa -- because when the turbo comes on it increases pressure in the head by as much as 17:1and thats one reason the turbo engines take more stress -- keep that in mind if you seek longevity
bad ‘ inaccurate , not explained correctly, bad advise, really old school very antiquated information for a Turbochargers in this decade or just wrong information in RED!
Old Feb 3, 2025 | 06:29 PM
  #22
Vroom Vroom's Avatar
This sounds normal - for a turbo which in effect uses the engine oil to cool the turbo- thus engine oil goes thru the turbo which gets very hot and desecrates the oil more rapidly than non-turbo combustion engines. If you are spooling the turbo frequently and drive aggressively it can shorthen oil life quickly --- If you treat your vehicle well , allowing turbo cool down after spirited driving and perform frequent oil/filter changes -you should be fine - I wouldnt be concerned about blow-by or oil leaking past the rings with this young of an engine. If you see a loss of a quart after low mileage ( 3000 ) oil changes - then you may have cause to be concerned - Keep performing the engine oil / filter service - There appears to be a few people on the net that like taking shots at Mazda and exaggerating reports of burning oil in these high compression skyactive engines at low mileage -- If you break it in correctly you should have no issues as these engines are what make Mazdas great - Theres a few others in here going off topic into transmission services - which I will not reply to because it creates confusion and is why we try to stay on topic --in this case - dirty engine oil - Remember Mazda dropped the compression in the turbos 10:1 from 13:1 usa -- because when the turbo comes on it increases pressure in the head by as much as 17:1 and thats one reason the turbo engines take more stress -- keep that in mind if you seek longevity
Thanks retread 888. This is accurate, common sense information I actually expected when I posted. But then I received crazy, overzealous, and interesting information to say the least. Yes, Mazda did lower there compression ratio for the Turbo as necessary. And even at that 10.5:1 is one of the highest for production turbo car. Of course I'm sure you already know they were able to do that because of the design of the Skyactiv technology. Yup, I was aware of the additional heat produced by oil passing through turbo charger. Those things do get hot, old school or new School 😁. Yes, I think I wil just keep changing my oil when it gets dirty. Around 4k.
I did break it in properly. 👍 I was lucky enough to get the Mazda right off the truck, (watched them pull it off). So no crazy test drivers hammering it
Thanks 888.
Old Feb 4, 2025 | 06:33 PM
  #23
retread888's Avatar
Enjoy your CX5- I think its great you are paying close attention to the basic stuff that keeps you on the road --It makes me think when I read these questions ---Nice job grabbing a unit off the truck !!!
Old Feb 4, 2025 | 11:09 PM
  #24
At least 2 member seem to be in this category
can you say vaaarooom3.8s?
See post response #20
67vette
Feb 15, 2025 09:16 AM
Philrobj
Sep 16, 2024 11:11 PM
Sojourner55
Dec 8, 2021 06:44 PM
IvanLawrence
Oct 29, 2008 07:06 PM
