2018 Mazda CX5 Infotainment system dark screen
Old Jun 7, 2021 | 03:58 PM
csurn's Avatar
Default 2018 Mazda CX5 Infotainment system dark screen
2018 CX5 has Dark screen and not working with bluetooth on phone. It does say connected on phone bluetooth setting. Have tried the reset of holding down the buttons for 10 sec as suggested in postings. Can’t find answer in manual.
Old Jun 8, 2021 | 06:37 AM
miltbaker's Avatar
Could it be a blown fuse?
Old Jun 8, 2021 | 10:51 AM
csurn's Avatar
Thank you for the reply, I’m not sure as I’m not mechanical, but there is radio volume, wouldn’t that be not working if fuse was out? I just wasted another 1-2 hrs yesterday reading the manual, very frustrating. I just traded in another problem car for this. Just can’t trust reviews any more.
Old Jun 8, 2021 | 11:18 AM
miltbaker's Avatar
Keep in mind that the fuse that leads power to your radio/audio system may not be the same one as the fuse that leads power to your screen.
As the CX5 owners's manual says: Your vehicle's electrical system is protected by fuses.
If any lights, accessories, or controls do not work, inspect the appropriate circuit protector. If a fuse has blown, the inside element will be melted.
If the same fuse blows again, avoid using that system and consult an Authorized Mazda Dealer as soon as possible.
Old Jun 8, 2021 | 12:45 PM
securityguy's Avatar
There is only one fuse to a radio and the screen is, most likely, tied to that fuse.
Old Jun 10, 2021 | 09:54 AM
csurn's Avatar
Thank you for the advice. The screen is on, the brightness can’t be accessed so I can see it. Is this fuse related or is there a control or dial that can adjust this?
Old Jun 14, 2021 | 05:35 PM
Tim Turner's Avatar
From the wiring diagram 4-5 fuses; Room (CMU, Display & AUX/USB/SD), Audio (main fuse for tuner and amps) Audio 1 for tuner & amp, Audio 2 for commander switch and Bose for Bose amp if equipped.
Old Jun 14, 2021 | 05:40 PM
TB250's Avatar
Have you tried adjusting the dashboard illumination ****? Do your other dash lights work?
Old Jun 14, 2021 | 05:54 PM
CarpeDiem's Avatar
Cool
^^^This^^^ Many with similar problems fixed them by turning the dash illumination stem in the upper right of the dash display.
Old Jun 14, 2021 | 06:00 PM
Tim Turner's Avatar
Default '18 CX-5 wiring diagram
This may not be the proper wiring diagram as there are around a dozen different ones depending on the options so a random one. Looking at this I'd see if a USB device powers up in the front slots - yes = ROOM fuse is OK, we have sound so AUDIO, AUDIO1 and BOSE (if equipped) should be OK, if the commander ***** control the volume AUDIO2 is OK
If you are lucky it could be a bad connection between the CMU & the display or elsewhere but likely to be the CMU or display - $$ I know I replaced hundreds of screens on Cadillacs but only a handful of HMIs (equivalent to CMU) but I don't know which gives more problems on Mazdas.
I retired after 36 years specializing in automotive electrical/computer/networks so TY; this was a fun brain exercise!
awconverse
Sep 1, 2020 11:31 AM
oturn
Dec 17, 2019 01:52 PM
shootnpar
Oct 8, 2018 12:44 PM
mactoolsix
Aug 24, 2018 04:01 AM
Rachel Krausman
Aug 28, 2013 09:52 AM
