2014 Mazda CX-5 code PO722
Old Dec 2, 2021 | 01:47 PM
jimmyp's Avatar
Default 2014 Mazda CX-5 code PO722
hi ,
ok well this thing has 97,000 on it , she bought it used about 2 years ago . Was running fine an then yesterday up pops Service Light (solid on not flashing ) had code pulled - PO722 .
what can anyone tell me about this .
is the solenoid on the inside of the Trans or out , An how much of a bear are they to change . Oddly I had told her that morning her car was pushing 100,000 miles an we should get the Xmission serviced at the next Eng oil change , I guess it overheard me , dang car ,,, Thanks
Old Dec 2, 2021 | 04:43 PM
m5xguy's Avatar
There's very little information available on repair of the newer Mazda automatic transmissions, probably due to not much bad happening to them so far. But the scant information in the FSM indicates that the speed sensors and TCM are 'built into' the valve body. And that appears to be confirmed by the fact that these parts are nowhere to be found individually.
Owning a newer vehicle, this is the first time I've searched for information on the newer Mazda transmission internals. So with very little research, I'm not in any way certain that this is all correct. But if what I'm seeing so far is true, then that would certainly be VERY bad news for you, because it means the entire control valve body (big $$$) would need to be replaced if a speed sensor has failed. And that would be the absolute pits. I suggest giving your local Mazda a call, in order to see if they can confirm if what I'm seeing is correct. I certainly hope for your sake it's not true, and that the speed sensors (and TCM) are available somewhere and can actually be replaced.
kapk22
Oct 3, 2021 01:52 PM
Joel Rogers
Mar 2, 2020 03:51 AM
expatCanuck
Oct 19, 2019 07:04 PM
Daithi
Mar 25, 2018 08:18 AM
Din.adeel
Jul 24, 2016 12:40 PM
