Driver’s door wont open from the inside
Hey guys,
This morning I couldn’t get out of My 2020 mazda cx30 GX from inside from my driver’s door when everything was unlocked and windows were functional. i had to clinb over to the passenger’s side to get out. Once outside, I tried to open the driver’s door and it worked! Any ideas why? Should i bring it to the dealership for an inspection?
thanks!!
thanks!!
Yes everything was turned off (so i guess the park brake was also on) because I had parked my car and ready to get out.
Hey guys,
thanks!!
thanks!!
yes nothing worked. It seemed to be an issue during winter only… (canadian winter)
It seems to be an issue during winter only… (canadian winter) because now that the weather had gotten warmer, it never occured again
So you never had to take it to the dealer? Did it just start working again randomly? Did you do anything? I’m just about to go on a driving holiday and wondering if I need to try and book into a dealer. Of course it’s happened right before a 4 day weekend!!
Hey guys,
thanks!!
thanks!!
Same thing just happened here. (I'm not a mechanic so correct terminology isn't going to be used) Took of the door panel to see whats going on ended up being the dowel holding the cable poped out of place due to the top cap of it braking off (some sort of cheap plastic that gets weak in the cold). I just put the dowel back in place with some heavy adhesive as the pieces doesn't need to rotate just not fall out of place. Hope this helps
