CX30 Ride Quality
Old Nov 9, 2024 | 03:11 PM
Wheelyscott's Avatar
Default CX30 Ride Quality
Hi all I'm loving my CX30 GT Sport skyactive x 21 plate. The only downside is the very firm ride on the 215x55x18 wheels + tyres.
Would changing the wheels to 16 rims either 215 x 65 tyres make much difference worth the £800 outlay or is the suspension too stiff and any difference would only be marginal. Look foward to any tips, advice and suggestions!
Old Nov 10, 2024 | 11:25 AM
Tires type (comfort or road noise rating) have the highest and direct influence on ride quality *not really the wheel size(*to some degree). Also by lowering the tire pressure to the safe minimum will directly influence the feel. But also may slightly increase MPG.
Old Nov 10, 2024 | 11:39 AM
Thanks yes I have reduced the front to 33psi and the rear to 34.5psi and it's slightly better than the 36psi that were previously on all 4 tyres.
Old Nov 10, 2024 | 11:40 AM
Do we know what the safe minimum is please?
Old Nov 10, 2024 | 12:37 PM
If you monitor and check the tire psi for changing influencers ......The Max. tire pressure less 4-6 lbs to account for heat normally developed in the tire by driving as well the ambientes and the temperature of the tarmac.
Remember the first effect of a lower tire pressure is a slight increase in steering feedback also a slight drop in MPG. Braking may not necessarily be affected depending on the actual tread design.
You may need to reset the TPMS
MBF1216
Feb 9, 2022 10:52 AM
WTMazda
Mazda CX-30
May 1, 2021 08:15 PM
Charlesviiii
Apr 7, 2019 07:28 PM
k3nnis
Feb 24, 2019 05:29 PM
Rubenau30
Aug 17, 2010 03:25 PM
