Wobbly mirror glass in B2200 tow mirror
Old Jul 16, 2022 | 12:22 PM
Cusser's Avatar
Default Wobbly mirror glass in B2200 tow mirror
About a decade ago, I posted (likely on the MazdaTrucking site) about the mirror on my 1988 B2200 Cab Plus driver side "tow" mirror wobbling/wiggling at highway speeds, and I'd narrowed that down to the mirror part itself. I had asked if anyone knew how to take these apart to repair this, but got no replies.
Anyway, I finally decided to get gutsy and attack this myself today. My first idea was to tap in gently some small wood shims (and use silicone glue) to hold the glass tighter, and then paint the shims black. Well, this morning I took another look, and saw that the bottom edge of the glass was not securely attached, so I gently pried the glass off, and found it had been silicone-glued to the plastic housing back in 1988. So I took the mirror off the truck - so I could use gravity to hold the mirror in place (instead of using masking tape). I cleaned up the silicone glue still attached to the mirror and the plastic housing, and applied Permatex silicone adhesive, and mounted the mirror in my bench vise and used two Craftsman NiCad batteries to hold the mirror down as the silicone dries. I'll let this dry 24 hours, then re-install, and just will drive my 2004 Frontier today (this 143hp 4-cylinder, 5-speed Frontier King Cab is an improved, safer cousin - air bags, ABS - of the B2600i I never had).
Old Jul 16, 2022 | 05:16 PM
MeB2000's Avatar
I added my original "Tow Mirror" thread that I made years ago over at Mazdatrucking.com site, into the "mazdatruckin.com thread" here (Post #29):
https://www.mazdaforum.com/forum/maz...e3/#post189727
Just in case anyone was curious about how to fix them once they get "loose" ........ sometimes the aluminum vertical "pole" that the mirror head slips down onto, becomes loose at the mirror "arm" that holds it......mainly from owners not keeping the mirror head lubricated where it slips on the pole.
Old Jul 17, 2022 | 08:36 AM
Cusser's Avatar
Earl - I do remember and had "archived" your previous post, but that didn't help with my mirror wobble !!!
And I always figured that a used driver tow mirror from a different state would be in worse physical condition than my Arizona one. I did buy a set long ago at the parts yard, but sold that set long ago....before I had wobble.
Old Jul 18, 2022 | 05:19 PM
Cusser's Avatar
OK, drove the B2200 today 25-30 miles, and I can report that it's 100% fixed.
Old Aug 10, 2022 | 04:16 AM
MrCommandoMan's Avatar
[QUOTE=MeB2000;206442]I added my original "Tow Mirror" thread that I made years ago over at Mazdatrucking.com site, into the "mazdatruckin.com thread" here (Post #29):
Thanks to Viagra my pole no longer "wobbles" like Cusser says his does.
slpatton
Jan 28, 2019 12:39 AM
Beginn_er
Mar 8, 2018 03:34 PM
McLovin
Oct 6, 2013 01:33 PM
AD4M
Jun 9, 2009 04:34 PM
fruitbooter13
Jul 15, 2008 04:44 PM
