Ute won't start when hot. Bit of a different one.
Old Mar 16, 2026 | 09:06 PM
Shadowboxer's Avatar
Default Ute won't start when hot. Bit of a different one.
Hi I own a 2011 bt50 turbo. Here's what's going on. When left to cool in the night when I go to start the yellow squiggly glow plug light comes on and the old girl fires and runs perfectly. But if I heat it up then turn it off when I go to start it just spins properly but without that yellow light appearing will not start. I'm mystified. It seems to be affected by temp and or humidity. I live in Brisbane so it's usually warm. A scan showed nothing apparently. Everyone has a different theory. Help please. I have changed the glow plug relay and have the glow plugs ready to go in. Thanks in advance for any help.
Brent.
Old Mar 16, 2026 | 10:07 PM
Charlescrown's Avatar
First thing scan for codes. Your symptoms sound very much like a failing crank sensor but lets not guess. If your car has a tacho does it show a reading of around 200-300rpm when cranking when the problem occurs?
Old Mar 16, 2026 | 10:30 PM
I will check thank you.
Old Mar 17, 2026 | 07:19 AM
2011, is that the older UN chassis or the later UP chassis?
The UN BT-50 did have issues with electromagnetic interference from the starter motor to the CAM/CRANK sensor.
tonyb760
Mar 16, 2026 11:06 PM
WilliamJ
Nov 28, 2021 08:59 AM
AdhamX33
Apr 18, 2018 03:07 PM
djdiamond
Aug 18, 2011 07:21 PM
telcmsuk
Jun 23, 2008 03:28 PM
