Slave cylinder problem?
Old Aug 12, 2012 | 01:13 PM
sasjzl's Avatar
Default Slave cylinder problem?
Hi,
I have a 1989 B2200 and recently the clutch has been in one of two modes.
Very, very stiff to the point that I cannot get it fully depressed or stuck on the floor and I have to pry it up. I just tries bleeding it and was able to see a stream of fluid shoot out but the pedal went straight to the floor and had to be
pried up. Then I was back to the super stiff pedal.
I don't know what it could be except the slave cylinder not working.
Which kind of confuses me because this slave cylinder is months and a couple of hundred miles old. I know the slave cylinders are known to be a weak spot on this truck but I wanted to see if anyone has any other ideas or can tell me how I can be sure that it is the slave cylinder acting up.
Thanks very much,
Jim Lee
1989 B2200
Old Aug 12, 2012 | 01:15 PM
MazdaTirol's Avatar
Sounds like the throwout bearing is sticking, how many miles/kms on the truck?
Old Aug 13, 2012 | 09:43 AM
sasjzl's Avatar
Now you are scaring me.
189k but I just rebuilt the engine and replaced the throw out bearing about a year ago. If it is the throw out bearing is there anything I can do without dropping the transmission?
You are probably right though because a while ago I found that the pedal went
straight to the floor but I was able to pry it up and it worked fine, for a while, after that. That might have happened twice. This is the first time though that it has been 'stuck' in the 'up' position.
Thanks very much,
Jim Lee
Old Aug 14, 2012 | 05:24 AM
MazdaTirol's Avatar
Did you lightly grease the shaft the throwout bearing slides on? Some transmissions have a grease zerk that can be used to lube the shaft without removing anything.
Old Aug 14, 2012 | 05:47 PM
sasjzl's Avatar
I do not remember specifically but if the workshop manual said to do it I did it.
I think I am going to remove the save cylinder from the transmission and see if I can actually see the slave cylinder rod move. If that is the problem I will be very happy.
Thanks,
Jim Lee
Old Oct 16, 2012 | 11:27 AM
sasjzl's Avatar
Hi all
Sorry it took so long for me to reply on this thread but the problem was the slave cylinder pinion (?) had frozen up...which made me very happy because all I had to do was replace said slave cylinder at a cost of like 16 dollars. I am surprised how quickly this truck goes through slave cylinders. It was really seized up and not very old at all.
Thanks very much,
Jim Lee
Old Oct 28, 2012 | 07:40 PM
Cusser's Avatar
Jim - I had this happen on mine about a dozen years ago. I replaced both master and slave cylinders because both were lifetime-warrantied.
Did you ditch the mazdatrucking.com board?
candido
Apr 25, 2014 07:04 PM
kayak-1
Jul 29, 2013 06:36 PM
tomaco1
Jan 26, 2009 08:48 AM
raysoden
Oct 4, 2007 08:31 AM
backintime
May 27, 2007 06:03 PM
