Need B2200 Door Panel Clips Info
Old Apr 20, 2019 | 09:31 AM
joshhemming's Avatar
Default Need B2200 Door Panel Clips Info
The windows in my '88 B-2200 are becoming difficult to roll up and down. I want to remove the door panels so I can clean and lube the assembly inside. I know from experience with other cars that most of the plastic retainer clips will break when the panels are removed. I'd like to order 20 or so of them to have on hand.
One source I found online says the original Mazda parts numbers for the clips are GJ6A-68-AB1 or G350-68-AB1. But another source says the GJ6A number is not compatible with the B-2200. Anyone know for sure what the correct part number is for these clips?
Old Apr 20, 2019 | 01:40 PM
Cusser's Avatar
These clips don't break that readily on these trucks; I have spares I grabbed at the parts yard. Get a door panel clip tool
Old Apr 20, 2019 | 08:28 PM
Thanks, I've got one of those tools. Do you have a picture of a window crank removal tool that will work on B2200s? Harbor Freight has one for $7 but they say it applies to Ford and GM vehicles.
Old Apr 21, 2019 | 08:59 AM
Cusser's Avatar
Josh - I don't have any special tool, never used one. I've used a small pick and hook set, like from Harbor Freight, to pull the horseshoe clip back and out. Sometimes a small screwdriver will work. Push the panel in a little to access. Remember the window crank orientation if you care about stuff like that.
I think I'd get the $7 tool a HF (says GM and Ford WINDSHIELDS) and return it for refund if tool on the right doesn't work on the Mazda. Below.
https://www.harborfreight.com/4-piec...set-38386.html
Old Apr 21, 2019 | 11:09 AM
Thanks. I've got that very same hook and pick set and will pick up the $7 HF set of GM/Ford tools. I've got a 25% OFF coupon!!!!
Yamaha_Boy
Aug 20, 2018 12:52 AM
CharlyFh
Feb 2, 2014 08:53 AM
slikrider20
May 6, 2009 07:01 AM
mzdaspd304
Feb 17, 2007 10:03 PM
MichaelDunn
Feb 20, 2006 07:52 PM
