Mazda b2300 thermostat not working
Old Jan 15, 2025 | 07:51 PM
MAZDA B2300's Avatar
Default Mazda b2300 thermostat not working
Hello, I bought a brand new oem thermostat for my b2300 2.3l with the sensor. It's supposed to reset at 190 and doesn't. It won't reset at all, it just continues to 240 before I turn it off. What could make the thermostat not work and before this I bought a 3rd party one and the thermostat was stuck open I believe. It would get hot when I would push the gas and never reset and then when you let off it starts cooling off. Please help me
Old Jan 15, 2025 | 11:02 PM
MeB2000's Avatar
If your engine is overheating (or has) it may not be the thermostat......your radiator could be the issue, or water pump, or radiator cooling fan(s), etc. If the thermostat is opening, it's doing it's job......in that case, something else in the cooling system is not doing it's job!
Old Jan 15, 2025 | 11:06 PM
Hey, the thermostat never opens. When it gets to 190 it just keeps going up
Old Jan 16, 2025 | 07:44 AM
Cusser's Avatar
1. Install a Stant thermostat.
2. Bleed out ALL the air out of the cooling system. If necessary, jack up front of truck, take radiator cap off, start engine, let run for 20 minutes adding 50/50 coolant as necessary.
Old Jan 16, 2025 | 08:48 PM
MeB2000's Avatar
Some thermostats can be installed the wrong way.......where the portion/side that should face the engine side of the coolant, is installed facing the radiator side of the coolant, and therefore doesn't open. Make sure that you have the thermostat installed correctly. It happens, and it is more common than you would believe!
Old Jan 16, 2025 | 08:57 PM
Default Hey
The thermostat is on a housing, it's a all in one unit. It only goes one way.
Dustybin
Jan 26, 2021 06:29 PM
stevelee98003
Nov 17, 2011 09:41 AM
badgrafxghost
Jul 31, 2008 02:49 PM
Cipro
Nov 1, 2007 04:25 PM
CO2Man
Jun 8, 2007 02:00 PM
