i need help on a b2200 motor swap
Old Apr 29, 2008 | 12:21 AM
Suzuki191's Avatar
Default i need help on a b2200 motor swap
I just recently bought a 1988 b2200. Will a f2t(626 turbo, mx6 turbo, and the ford probe gt turbo)bolt right into it. i really do not want to have to do any welding. What is the best thing i can do. What about a 5.0? thanks
Old May 28, 2008 | 07:12 PM
screwtumhead's Avatar
Default RE: i need help on a b2200 motor swap
i got an ft2 in my mazda b2200 8v
so if u want to cut the firewall u can use f2t with its 16v head cause trottle body and distributer facing that side or use an f2t bottom end and the stock b2200 head 8v with an mx6 intake manifol and if u willing to spend the money u will need an e-manage and it will push over 200hp to the wheel with no e-manage dont go more than 6 lbs boost and it over heats alot without the emanage
Old May 29, 2008 | 11:53 AM
Kyrasis6's Avatar
You better go take another look at you're engine because the F2T uses a 12-valve head, the 16v is a completely different engine and the intake manifold from the 12-valve head doesn't even come close to fitting the 8 valve head on your truck.
The exhaust manifold from the F2T does however bolt right up to the F2 8-valve.
Old Aug 3, 2008 | 05:28 PM
schmeefus's Avatar
Will the piping and intercooler from an MX-6 or Probe GT work on the F2 truck?? Will putting a turbo on an F2 with and auto trans have any performance/reliability issues?? Will the auto trans take the extra power without issue?
Old Aug 3, 2008 | 09:25 PM
metruis02's Avatar
do they make a turbo for the '88 b2200
Old Aug 3, 2008 | 10:51 PM
schmeefus's Avatar
All the information I am finding shows the manifold and turbo from a 2.2L F2T motor from 88-92 Mazda MX-6 and Ford Probe GT will work on the B2200 from the same years.
mazdaidk
Feb 28, 2014 04:34 AM
bagged mazda wit V8
Nov 9, 2009 05:17 PM
kegroening
Jul 13, 2008 05:30 AM
90mazdab2200
Nov 8, 2007 08:01 PM
89MazdaB2200
Sep 16, 2006 03:19 AM
