Gearbox swap. 90GB into 88 car. No fit.
Old Feb 21, 2021 | 04:16 AM
Paavo Ruokojärvi's Avatar
Default Gearbox swap. 90GB into 88 car. No fit.
Replacing my sons shot gearbox in my 88 b2600 4x4 with a GB from a 1990 B2600i
Turns out that it wont go in because of to long inputshaft when change of bellhousing.
Tryed to cut 10 mm off but now it feels like the splines are bottoming out against the centerbearing.
I have as I see it two options.
Grind down the top off the splines och removing centerbearing.
The new gearbox is only temporary and will be swapped as soon I find another.
How long does a gerabox last without centerbearing?
Its a special youth-car restricted to 30 km/h and gears 4 and 5 are restricted.
Runs mostly on 3rd gear around 1500 rpm.
This the new GB cut.
New GB uncut.
Old GB
Old Feb 24, 2021 | 07:42 PM
Jerry C's Avatar
Where ya at ?I've never heard of a youth car. Id say just get a dremel an grind down or just be super careful when engaging gear.
Old Feb 25, 2021 | 05:51 AM
90-B2200's Avatar
Is it possible that the bell housings and input shafts are interchangeable? I mean, if the input shaft on the old trans is ok, maybe it will interchange along with the belhousing to make a hybrid assembly that fits properly.
I for one, would not run it without a properly fitting pilot bearing that is engaged in the input shaft like it should be.
Nina Frohlicher
Jun 14, 2023 04:16 PM
rolla
Mar 9, 2021 03:28 AM
JollyRancher
Jan 9, 2021 03:22 PM
Captain Mazda
Jun 4, 2011 12:55 AM
mazdab2600
May 23, 2009 08:52 PM
