changing carb on 90 b2200
Old Aug 4, 2008 | 10:36 AM
MUST9819's Avatar
Default changing carb on 90 b2200
was curious as to how hard this will be to change out???? just ordered it should be in a couple days.mech says it needs one. starts up fine but when cold and gas is applied it bogs down and wants to quit.when it gets hot it wont start back until cooled off or with starting fluid.
thanks
Old Aug 4, 2008 | 02:20 PM
Cusser's Avatar
Default RE: changing carb on 90 b2200
I've replaced carb with a Weber, that was straightforward. Make sure to label REALLY GOOD all the vacuum lines or you'll be sorry !!!
Old Aug 11, 2008 | 01:49 AM
jst315's Avatar
It took me about 1 full day. Not very difficult.
Old Aug 11, 2008 | 05:43 PM
Ricks b2200's Avatar
I swapped out my son's carb for a weber 32/36 because it was pooring black smoke, now it idles fine but when you give it gas it wants to bog or die. The instructions said to plug the fuel return line , could this be the problem? B2200 AT Electric pump and pressure regulator set at 3.5 psi.
Willie2124
Jun 17, 2009 11:29 PM
wooddy
Nov 4, 2008 08:38 AM
lwgerwitz
Aug 6, 2008 04:32 PM
mth
Aug 6, 2008 03:55 PM
blasphemous
Feb 28, 2007 03:02 AM
