Brake pedal on floor
Old Jan 7, 2007 | 07:19 PM
1owner's Avatar
Default Brake pedal on floor
Changed out master cylinder twice on my 1991 B2200. Can't get the pedal back up to normal operating range. Bled according to Chilton procedures. Any thoughts?
Old Jan 7, 2007 | 10:45 PM
nastynate's Avatar
Default RE: Brake pedal on floor
need new brake pads? I believe their is a bolt behind the brake booster than can be adjusted so that the push rodin the master cylinder is closer, but no touching, the piston in the master cylinder.
Old Jan 7, 2007 | 10:52 PM
monstermazda's Avatar
when you bled them how much air came out of each?
Old Jan 7, 2007 | 11:00 PM
nastynate's Avatar
with adjusting the break booster push rod, their are certain measuresthat have to be takin. Fairly complex.
Old Jan 9, 2007 | 01:05 AM
nastynate's Avatar
did you bench bleed the new master cylinder?
Old Jan 10, 2007 | 12:45 AM
1owner's Avatar
This one is definitely SOLVED. Both of the calipers were frozen in their mounts. Disassembled and cleaned. Back to new. ball joints are next...
Old Jan 11, 2007 | 12:12 PM
nastynate's Avatar
someone just asked about ball joints in this forum, you can look their, if not just stop and ask if you need any assistance.
tgames64
Nov 22, 2013 06:10 AM
krasts.ag
Aug 14, 2013 07:43 AM
JohnnyP
Nov 17, 2008 07:39 PM
bbspin
Jun 20, 2007 08:28 AM
mitch
Jul 21, 2006 11:00 PM
