B2600 dowel engine to transmission
Old Aug 29, 2020 | 02:40 PM
skillethead's Avatar
Default B2600 dowel engine to transmission
I am in need of at least one dowel to line up the engine and transmission or if the size is known that would help. This is for a 1987 B2600 Mazda 4X4 pickup, Motor is overhauled and is waiting to be put back in the truck.
Old Aug 30, 2020 | 03:11 AM
Have you tried your local dealership?
Old Aug 30, 2020 | 09:24 AM
Cusser's Avatar
And that is a Mitsubishi engine in that year.
Won't the transmission shaft and the mounting bolts be sufficient?
Old Aug 31, 2020 | 07:32 AM
Dowels are super important. Bellhousing bolts alone will not suffice.
I made the simple mistake of not swapping dowels over when replacing a BT-50 3.2 diesel engine.
Within a couple of thousand kms, the transmission & torque convertor shat themselves. Retail repair cost of $6000 & a written warning to me
Old Aug 31, 2020 | 09:01 AM
Cusser's Avatar
Wow. I'm an old air-cooled VW guy, and those engines/transmissions do not use dowels for mounting.
Old Aug 31, 2020 | 08:57 PM
That was the first place I asked and no they said they could not order them. I found some on the Grainger site, but not sure about size.
Old Sep 1, 2020 | 08:00 AM
Cusser's Avatar
Did you try a Mitsubishi dealership, inquire for the same engine? There must be listings somewhere which detail which Mitsubishi vehicles use that same engine.
I'd also guess that a machine shop could make such dowels.
Old Sep 2, 2020 | 07:32 AM
Could always check with the wreckers.
andrewculp15
Jan 13, 2016 09:40 PM
2blue
Off Road
Oct 29, 2012 01:26 AM
erikhshepard
Dec 2, 2011 04:36 AM
bryan26
Feb 15, 2006 10:04 PM
90B2600I
Nov 4, 2005 10:37 AM
