b2200 ignition switch
Old Jun 12, 2010 | 10:19 AM
fantknee's Avatar
Default b2200 ignition switch
i have a bad ignition switch in the run position .is there any way to bypass the switch,with a second switch
Old Jun 14, 2010 | 11:21 PM
Cusser's Avatar
Sure, there's a way. I'd recommend a new switch, however. But if you want to install a 30 amp toggle switch, I'd only solder a new wire onto the existing wire (scrape away some insulation, don't cut the wire as you or someone else may want to fix it right someday, you just want to give the voltage an "alternative path") through the toggle switch, then splice from the toggle switch to the run wire (again, strip, don't cut)...
infared067
Mar 25, 2009 11:39 PM
nbrsguy
Dec 26, 2006 02:08 PM
condor
Apr 15, 2006 03:02 AM
ripcbx
Dec 26, 2005 09:28 PM
almstl8
Sep 18, 2005 11:29 AM
