91 B2600 Intermittant Missing
Old Oct 6, 2009 | 11:38 AM
MazdaSTL's Avatar
Default 91 B2600 Intermittant Missing
My '91 B2600i 4X4 starts and runs great, but has an intermittant miss that comes and goes. Sometimes it will run fine for 2,3, 5 miles, then stumble and miss on and off for a mile or so, then run fine again. Have replaced coil, wires, cap, rotor, plugs, and fuel pump. It almost acts like a vapor lock kind of a problem, but it doesn't seem to need to warm up much before the problem starts. Driving me nuts (short drive!). Suggestions?
Old Oct 18, 2009 | 09:01 PM
f350powerstroke01's Avatar
I just bought a 93 b2600I and it does almost the same thing that you described. I have replaced same parts as you except for the fuel pump and my coil was good. Still have the same problem. If you find a cure please let me know! I will do the same. Thanks!
Old Oct 22, 2009 | 03:29 PM
MazdaSTL's Avatar
Have you replaced your ECU?
Old Oct 26, 2009 | 09:23 PM
lynch2600's Avatar
make sure your plug wires aren't touching metal, you might also check for any loose wires, alot of times intermittent problems are caused by a loose connection or a bare spot on a wire grounding out
mazda626h
Feb 23, 2014 09:00 AM
emanuel
Aug 23, 2010 12:28 PM
rogerbohl
Mar 20, 2006 10:22 PM
chaznw
Jul 29, 2005 02:01 AM
