1996 B3000 won't start
Old Jul 3, 2016 | 11:13 AM
sundowner3000's Avatar
Default 1996 B3000 won't start
Good afternoon folks. I hope your holiday is going well.
Went out this morning to make a short trip and nothing..as in turned the key on, all the instrument lights came on but not a sound from the engine. Battery is good but not even a click when the key is turned. Tried starting in park and in neutral with no luck. Wanted to try tapping the starter but how can I get to it? Any ideas? Didn't see anything in the stickies section.
Thanks for any replies and enjoy the rest of your weekend.
Robert
Old Jul 5, 2016 | 07:16 AM
Cusser's Avatar
How do you KNOW that the battery is good? A 12 volt reading when not under load doesn't tell much. Did you try jump-starting from a running vehicle? Did you measure voltage across the battery terminals when trying to crank 10 seconds?
Typically, if connections are good and clean, then 85% bad battery, 10% bad electrical part of switch or neutral safety switch, only 5% bad starter. But check it out first !!!
See FAQ #28 at marksalem.com
Old Jul 6, 2016 | 06:47 AM
I think these utes have issues with worn out /faulty ignition switches. Something to look at after getting the battery properly tested.
Old Jul 6, 2016 | 09:01 AM
Cusser's Avatar
His 1996 B3000 is USA, so a Ford Ranger in reality. Not a Japanese-made B-series as were 1993 and earlier here which were known for ignition switches that went bad over time.
Old Jul 6, 2016 | 09:14 PM
Thanks for the replies. I didn't mention that I called a tow truck and he tried to jump the truck with no luck. I haven't had the battery checked out. Will do that tomorrow.
Old Jul 6, 2016 | 10:43 PM
Cusser's Avatar
When tow truck guy did this: did the starter spin the engine and it just wouldn't start, or did the starter fail to spin the engine ???
At least you didn't post "she won't turn over" - that's a sex question !!!
Old Jul 6, 2016 | 10:58 PM
Lol. It didn't do anything. No click, no whine, nothing. Thats why I thought it was the battery until the tow guy jumped. I bought a battery from Costco and put it in and it did the same thing so I took the battery back. I was in the Costco parking lot.
Old Sep 10, 2016 | 09:56 AM
After letting it sit for awhile, it was the starter. Thanks for the replies.
Old Sep 10, 2016 | 01:06 PM
dragonmp5's Avatar
Why do they go bad and how can you tell if its been changed for a better switch?
Old Sep 11, 2016 | 08:12 AM
Cusser's Avatar
The electrical contacts go bad with time and usage.
hychamaz
Jun 15, 2013 09:01 AM
autotran
Apr 22, 2013 03:58 PM
wcane
Nov 8, 2010 05:54 PM
wcane
Nov 8, 2010 02:32 PM
Tallulah
Aug 14, 2009 06:45 AM
