Very strange problems with left signal light
Old Jul 29, 2008 | 06:49 PM
Nainduck's Avatar
Default Very strange problems with left signal light
I have just spent a few hours researching this problem and I can find similar issues, but nothing quite as strange as this one. I recently bought a 1999 626 that was well maintained and is in good condition. After a few days I discovered that when my headlights are on and I put on my left signal light every light in the car starts to flash, the headlights, tail lights, stereo, dash, etc. These are all flashing faster than a normal signal light. When my headlights are off this does not happen. I checked the grounds on both sides of the car and had to replace the once on the left due to rust. I thought this would fix the problem and it didn't. If I remove the bulb from the left front signal light the problem goes away. I unplugged the sockets from both front lights and swapped them with no change. I checked the flasher module and it seems fine. As I said it works when the headlights are off. I can not find any damaged wiring anywhere. When I am under the hood with the left signal light and headlights on and ever light flashing in the car I could hear the relays under the hood in the fuse block there flashing. I started pulling them out and replacing them again it all of a sudden stopped. I thought I had it fixed but it started up again. Pulling these relays did not change anything this time. I have had this to a garage now and it is starting to get expensive with no end in sight. Any advice or suggestions? Anyone ever heard of this problem before?
Thanks for the help,
Howard
Mystere
Feb 7, 2011 08:56 PM
rnewby22
Jul 27, 2007 10:54 AM
mazdakorey
Jun 11, 2007 09:20 AM
chuckstang
Feb 5, 2007 09:13 PM
