STARTER STILL WON"T DISENGAGE
Will it not disengage because is mechanically stuck or electrically still energized???
Try pulling the small diameter wire from the ignition switch off at the starter and see if will then disengage then.
Maybe you are still getting a voltage signal at that wire after the key has been released from start position.
