overheating 626
Old Oct 14, 2008 | 06:34 PM
einarorn's Avatar
Default overheating 626
hi i am experiencing some heating issues with my mazda 626 1.8 96' , since i got it for about 9 months ago i always thought it ran a bit too hot,the other day it started toapproach the H , refilled it with water and antifreeeze, no change,
ran the heater on full helped a bit but not enough
swapped the thermostat, no change,
the fan was not turning on,even when the motor was reaching the Hso i disconnected the sensor switch and now the fan starts when the engine reaches mid range and stays on, no change, still overheats
swapped out the waterpump, no change
radiator seems ok, water is circulating in it, not getting bubbles in the water or steam from exhaustso head gasket ok.
any ideas???????
am getting to the point of swapping outthe motor completely
Old Oct 14, 2008 | 10:16 PM
wsoape281's Avatar
Default RE: overheating 626
sounds like you have a clogged heater core to me. that is all that is really left now. you could swap out the sending unit for the fan, but i really don't think that is the issue. pull the heater core and see how clear it is. you can bypass it or just replace it.
Old Oct 15, 2008 | 12:00 PM
Mazdatkb's Avatar
I would pull the radiator and have it checked/cleaned. Coolant could be circulating but still be restricted enough to cause overheating. My 96 Mx6 V6 developed a similar problem a couple years ago and although two techs said it was OK, it turned out to be the radiator afterall.
Old Oct 15, 2008 | 01:14 PM
einarorn's Avatar
ok
thanks for your input,I willpull outthe radiator and heater core tomorrow and flush them out, will report back .
einar
Old Oct 15, 2008 | 03:04 PM
Gimme3Doors's Avatar
Just be aware that if your car has automatic transmission, you need to disconnect fluid lines to the radiator besides the water hoses. My advice is don't remove the radiator unless you plan on replacing it with a new unit. The petcocks have a habit of snapping off after years of being in place. Watch out for this.
Old Oct 15, 2008 | 05:03 PM
einarorn's Avatar
it is a manual transmission but thanks for the heads up
Old Oct 16, 2008 | 12:57 PM
einarorn's Avatar
pulled the radiator out todayand flushed it out, seemed pretty clean inside and out, it must have been replaced not long ago, however no change still runs too hot and starts to overheat under load,
heatercoreseems toworkingthe hosesin and out are both warm,
going nuts !!!!
Old Oct 19, 2008 | 08:40 AM
99jc626's Avatar
well.. running out of things to look into.....
my othere car had issues with over heating like yours in the past.. did you check your catalytic..?? sometimes,.. clogged cats will overheat your engine.. obviously the hot exhaust not blowing out.. etc.. is your car having any accelation problems..?? losing power.. etc..?? well one area to look into.. good luck..
peterdragon
Jun 22, 2014 10:10 AM
Pierre
Aug 8, 2008 07:14 PM
skold
Jun 26, 2007 03:31 PM
Mr Moon
Jun 19, 2006 05:52 AM
cbg
Jan 3, 2006 09:27 AM
