Misfire on cylinder 3
Old Oct 22, 2012 | 02:01 PM
lime's Avatar
Default Misfire on cylinder 3
My car has had a long standing misfire problem. Basically there is a permanent check engine light on the dash. Every morning on cold start after about 1 mile of driving it will flash about 8 times and then stop. If I push the car hard it may flash again. During this car the car seems lumpy and sluggish. There is a real lack of power. Usually after that the misfire settles down and the light won't flash again for the rest of the day.
I did take the car to have the code read and they told me that it was a misfire on cylinder number three and that it was probably the plugs/wires.
I bought and fitted these parts and reset the code. The light stayed off for about a week but then returned. If anything, the car feels even worse when cold now.
The car also has a really low idle. Like between 1-200rpm. Sometimes as I pull away it feels like it might stall.
I have replaced the throttle body, the maf sensor, the air filter, the spark plugs, the front oxygen sensor, the ignition cables and have run a few cans of carbon cleaner through the car. I am not sure what else to do now.
Help
Old Oct 22, 2012 | 02:25 PM
1) While doing that work you should have disconnected the battery
SEE VIDEO: http://www.motorweek.org/features/go..._idling_issues
2) After the work you should have re-hooked up battery and let idle for 10 minutes before driving and let it re-learn for 50-100 miles (all at once not needed)
3) Not enough info: year, make, model, # cylinders, mileage, standard or automatic
4) how long have you been driving around with a misfire. Driving around with a misfire for a while leads to Catalytic Converter Failure.
READ: How can I tell if my catalytic converter is... — Yahoo! Autos
You should replace ignition coil(s) and distributor cap/rotor if you have one.
This thread is also a good read: https://www.mazdaforum.com/forum/maz...p-30242/page3/
CLEAN YOUR CATALYTIC VIDEO:
Old Oct 23, 2012 | 03:52 AM
lime's Avatar
Hi,
It is a 1.8 2001 manual model.
01MPV
May 17, 2007 01:44 PM
MrMan
Jan 24, 2007 06:08 AM
CardsFan420
Nov 8, 2006 06:25 PM
KuroRyu256
Jun 23, 2006 10:50 PM
JJ
Apr 30, 2005 10:39 PM
