mazda 626 one spark
Old Dec 26, 2013 | 08:31 AM
Tinymartin's Avatar
Cool mazda 626 one spark
Hi all, I have a Mazda 626 year 2000 petrol manual. One day it was working fine now it's not. I checked fuel which is plenty and when it turns over you can smell fuel out of the exhaust. I tried easy start and it still doesn't work. I checked the spark plugs and found that I have one spark only at the plugs no matter how long it is turning. I then changed the coil pack but that made no difference. I removed the camshaft sensor and check resistance which was .750 between the two posts. I've checked the fuses and all seems fine. Camshaft are turning when cranked. I'm pretty sure it is the camshaft or crankshaft sensor but can anyone help on how to test these properly how much they cost and where to get them cheap. Or if you know of any fault it could be. If you wish email me at martin_tiny@hotmail.com.
Old Dec 27, 2013 | 05:34 AM
Juanky's Avatar
are you getting any trouble codes? those two sensors usually trigger a trouble code when they fail.
Old Dec 28, 2013 | 03:12 AM
Tinymartin's Avatar
No code. Resistance on camshaft sensor is 750 ohms
Old Dec 28, 2013 | 07:55 PM
Juanky's Avatar
that sounds about good. the haynes manual says the crankshaft sensor should read from 950 ohms to 1.25 k ohms. did you check that the timing belt did not jump a couple or teeth? did you check compression, fuel pressure? first check that all timing marks are in place when at TDC.
scruffyvada
Jan 11, 2014 11:58 AM
mollysummer
Jan 7, 2009 02:43 AM
Mzda1311
Mar 9, 2007 09:30 PM
