Mazda 323 and Power cable
I'm not able to find any hole through the car interior to exterior at the driver side of my car. I need to run my power cable to the battery.
My car is Mazda 323 2001 model, can someone give me leads
Sounds like you are running a power cable from an extra amp or something.
If you remove stuff underneath the brake pedal area and remove the car battery, you can get a real good look and just drill a hole and put a rubber grommet around it or some silicone. Make sure you add an aextra ground wire to the battery as well as your stock ground won't be enough.
B18Eric
Sep 1, 2011 12:28 PM
