How to change a C.V. axle
Old Jan 17, 2009 | 09:59 PM
amcaver's Avatar
Default How to change a C.V. axle
both my cv boots are broken and i want to change the cv axle and all... anyone know how?
Old Jan 18, 2009 | 12:20 PM
darx's Avatar
Default RE: How to change a C.V. axle
hi... it is not a problem of know-how... it is more a practical matter... you need tools..nothing special, it is hard to explain without illustration..
When you have took off the wheel, remove the hub locknut (if you know what that is),then the lower control arm stabilizer bar needs to be un-loosend, disconnected, then goes the tie rod form the lower control arm, lower ball joint... and so on, and so on... complicated huh? My best advice is that you see a mechanic at least for advice if you are seeking to do it yourself... because it aint something easy to just explain just like this...
zr1mark
Oct 30, 2006 08:14 PM
fcastrovelez
Aug 26, 2006 11:42 PM
wadeski
Jun 19, 2006 03:21 AM
thomas1960
May 22, 2006 04:50 PM
daveo
Jan 1, 2006 12:17 AM
