Help on motor swap idea
Old Jan 20, 2010 | 01:23 AM
JDM_King's Avatar
Exclamation Help on motor swap idea
Hi i have an 88' mazda 626 and i was going to the 16b swap to it and my brother brought something to my attention that was interesting. I was wondering if you can take a 20b block and put a 16b head on it. im not sure so if you could help me that would be awesome
Old Jan 20, 2010 | 04:17 AM
wsoape281's Avatar
I'm sure that it's possible, but why? You could just take an fs (2.0l dohc) long block and drop that in. It will make more power and be a lot less complicated.
Old Jan 20, 2010 | 04:45 PM
JDM_King's Avatar
Default FS
would you recommend the fs-det or just the fs-de
Old Jan 20, 2010 | 11:35 PM
wsoape281's Avatar
Either one. They are the same block, but the management and induction are different. If you are going turbo build, I would swap a complete longblock with turbo, ecu, and harness in.
Old Jan 21, 2010 | 12:02 AM
JDM_King's Avatar
Default swap
thanks that helps alot
Old Jan 29, 2010 | 01:51 AM
alex91n/a's Avatar
well if he were to put the 1.6 head on the 2.0 block...wouldnt that be running higher compression? im pretty sure it would....which would be more power no? im not about the specs on these motors. but i know that in alot of other cars like hondas for example, if you take a b18 block(1.8) and throw a b16(1.6) head on it. you run higher compression and get a good amount of power out of it.
Old Jan 29, 2010 | 02:47 AM
alex91n/a's Avatar
oh unless of course the 1.6 head only comes in sohc and the 2.0 head is dohc. then i could see how the 2.0 head would be superior
mazdaidk
Feb 28, 2014 04:34 AM
bagged mazda wit V8
Nov 9, 2009 05:17 PM
Suzuki191
Aug 3, 2008 10:51 PM
mazda_minitruck92
Feb 4, 2008 09:45 AM
jesska
May 12, 2006 01:09 AM
