GASKETS, Got leak need HELP!!
Old Aug 10, 2006 | 02:56 AM
Alucard's Avatar
Default GASKETS, Got leak need HELP!!
Well looks like I have a small leak coming from my oil pan gasket.
Need to know how to replace this and any other seals I need to check when going about this.
I don't want to get underthere and star draining the oil and just try to pry the oil pan off untill I know I am not going to break something importand like my oil pump or bend my oil pan.
I know I can get the gasket and sealant for cheap.
But I need to know while doing this want else should I be checking? Are there any other gaskets or seal that I should just replace while I am doing this???
I need to know soon so I don't end up getting a bigger leak.
I want to get this fixed ASPA!
92 323 1.6lt
Old Aug 11, 2006 | 12:37 AM
bkey71's Avatar
Default RE: GASKETS, Got leak need HELP!!
the best thing is to read and understand the manual first. The oil pan gasket is easy but messy. There is no other associated gaskets when doing it. Just be prepared to get sloppy.
Old Aug 12, 2006 | 12:18 AM
Alucard's Avatar
lol oh great,
that much sealant? or just all that extra oil that is still all over the pan?
Do I need to drop my exhuast to remove the pan?
Old Aug 12, 2006 | 11:01 PM
bkey71's Avatar
don't know what you mean by "that much sealant? "
it gets messy because after the pan is removed the oil drips off the bottom of the engine from the oil pick up tube and crankshaft for example. just be prepared to wear some oil.
on my 87 323 i had to remove the exhaust down pipe to remove the oil pan since it is right under it. it connected to the exhaust manifold and went to the front of the catalytic converter.
Old Aug 13, 2006 | 09:02 PM
Alucard's Avatar
Was it hard to take off? I think I can just take of the down pipe pretty easily.
any brands when it comes to the new gaskets?
Old Aug 14, 2006 | 12:01 AM
bkey71's Avatar
it was easy to remove the down pipe. make sure to soak the bolts first for at least a half an hour so they don't break. use something like liquid wrench for that.
for the gaskets i have always had good luck with fel pro.
Old Aug 14, 2006 | 03:01 AM
Alucard's Avatar
Ok good advice, never had any luck with taking on those bolts off on other cars. liquid wrench eh? I will have to try that.
Yeah I like fel pro also I used them for my vaule cover gasket.
cyberspace
Nov 18, 2016 09:10 AM
WonovertoMazda
May 5, 2009 07:52 PM
AJ
Aug 1, 2007 12:29 PM
thedfo
Aug 1, 2007 08:23 AM
keninn
Sep 3, 2005 01:17 AM
