94 Mazda 929 Fuel Line diagram or location
Old Apr 14, 2007 | 11:17 PM
teknojunki's Avatar
Default 94 Mazda 929 Fuel Line diagram or location
Hi all. As a newb here I have tried to locate some information using the search. Unfortunately I have had no success. I need to find a diagram or picture of the fuel lines and their routes through the chasis. I have a fuel leak on my 94 929 and it pools under the tranny bell-housing.
Can anyone help?
Old Apr 16, 2007 | 05:13 AM
Sirob's Avatar
Default RE: 94 Mazda 929 Fuel Line diagram or location
teknojunki, try this http://929.sentia.ru/english.htm
Old Apr 16, 2007 | 05:59 PM
babyhuey's Avatar
If fuel is pooling at the bellhousing area then you should be concentrating on the fuel lines in the engine compartment.
The fuel lines come up into the engine compartment at left rear corner of engine compartment and then over the rear part of the left side valve cover. The line more to the front is fuel return and one to rear is fuel pressure from the pump. I would be looking at the pressure line first as it is more likely to leak and crosses over the engine rear right above where you are seeing the fuel.You may be able look at where this line goes by using an inspection mirror but may have to end up pulling the intake manifold as all of the lines, connection, pressure regulator, etc and fairly buried under it.
After the fuel line comes over the valve cover and under the manifold it connects to the pulsation damperat inside rear area of left valve cover, from there the fuel travels forward along the left bank fuel rail to a crossoverpipe across front of engine andover to the right bank fuel rail where it flow backwards to the pressure regulator. From the pressure regualtor a flexible line travels straight accros the engine to connect up to the fuel return line at the rear of left valve cover. Also note that there is a separate line that comes off of the fuel pressure regulator up to the cold start injector that is attached to the right rear of the intake manifold above the #5 spark plug area.
Old Apr 17, 2007 | 12:07 AM
teknojunki's Avatar
Thanks to both of you. I think I will be able to get this resolved now.
gregd
Dec 12, 2014 05:56 PM
maz10
Jul 18, 2010 02:32 PM
clicheche09
Apr 11, 2009 01:12 PM
Mazda2002
Oct 5, 2008 05:53 PM
