929 wont start
my 92 929 has low compression like 75 lbs , it should still start right?
RE: 929 wont start
Compression specs are 213 psi, with a minimum of 157 psi. Did you run a compression check on all 6 cyls? Did you do a wet compression check with a few ounces of oil in each cyl?
RE: 929 wont start
no i did not try that.
RE: 929 wont start
You need to check all cyls first. It is possible the timing belt is broke or has jumped time if all cyls are low.
RE: 929 wont start
Unlikely engine is going to start it all 6 cylinders have that kind of compression.
