929 92' Mazda - idle drops in R or D
Old Oct 18, 2005 | 07:25 PM
elbert's Avatar
Default 929 92' Mazda - idle drops in R or D
The car starts fine and idles okay. Once you shift the gear to R or D, the idle drops to a point as if the engine is ready to stall. You would hear some rough clanking sound under the hood as if there is no oil -- oil level okay. Shift it back to Park and idle goes back up. The car has about 60k miles. Any guidance is deeply appreciated.
Old Oct 18, 2005 | 11:11 PM
babyhuey's Avatar
Default RE: 929 92' Mazda - idle drops in R or D
Can you tell where the clanking noise is coming from? Make sure the engine is not moving excessively from a broken motor mount. They are kind of under the exhaust manifolds but you should be able to see them with a light while someone is shifting into and out of gear. Do you also get a significant idle drop in park with all electrical accessories on (ie, A/C, heater fan on high, headlight on, etc)? If so then you may have an idle air control valve not operating.
Old Jan 21, 2006 | 07:49 PM
Turbo's Avatar
Without knowing more about the engine noise, which the ISC can make a tapping/clikcing noise but not a load one, I would guess you have a bad ISC ( Idle SPeed Controler) otherwise known as the idle air control valve.
JS
May 5, 2009 11:08 AM
CTTribe
Aug 25, 2008 09:55 PM
blueag6
Dec 23, 2007 06:07 PM
XiL3D
Jan 21, 2007 12:16 PM
elso
Sep 23, 2006 12:39 AM
