626 GT gauge bezel removal
Hello all, I just found a 90 626GT in great physical condition...true survivor! I will post pics later as its a beaut!
Question: I don't want to break the gauge bezel as these are becoming un-obtanium...I took off the 3x screws on the underside of the top of the trim and the 2x down by the steering column. Is there another set of screws behind the oscillating vent or a switch or something? I don't want to pull any harder on the trim piece until I know its completely ready to be freed.
-Neen-
-Neen-
Yes, there's a hidden screw for removing the instrument bezel on the 88-92 MX6 and 626 models. The hidden one is behind a small half-mooned panel ( bezel if you will ) for the lever that controls the fresh air intake to the center oscillating air vents. Take a small screwdriver and LIGHTLY pry that small panel out and you'll instantly see the hidden screw. Then there's the 3 you mentioned, that point up BTW, above the cluster itself so 4 total screws and of course unhooking all things electrical. It's 5 or ten minute job and one that I've done many many times.
Arthur Gauvreau
Jul 11, 2010 05:08 AM
