626 gas tank replacement???
Old Nov 26, 2007 | 11:39 PM
burkhalter's Avatar
Default 626 gas tank replacement???
i just bought an '89 626 5 speed 2.0 L with a known leaky gas tank. its been driven in the salt and snow in minnesota so it has lost of rust but runs excellent. i need to replace the gas tank. anyone know how to go about that? i'm pretty good with cars but have never done a tank swap before.
i also have no E brake and i wanted to adjust the play in it before looking at replacing the rear pads. how do i get to the e brake adjustment?
Old Nov 28, 2007 | 09:10 AM
Mazmart Trini's Avatar
Default RE: 626 gas tank replacement???
It is held to the cars with straps. You have to disconnect all electrcal coonections & lines running to the tank. I woul also disconnect the negative cable from the battery first.
Old Nov 28, 2007 | 09:12 AM
The e-brake adjustment is probaly at the handle. Remove the cover & there should be an adjustment screw that you can turn with a flat head screw driver.
bdubbs84
Aug 6, 2006 03:54 PM
Mazdaboy2600i
Jun 25, 2006 09:43 AM
Mazdaboy2600i
May 21, 2006 03:16 AM
Glenn Smith
Jul 4, 2005 12:58 AM
