1993 Mercuri Capri (re-badged 323) power loss problems.
Old Sep 22, 2019 | 09:27 AM
Mark J Sherrell's Avatar
Default 1993 Mercuri Capri (re-badged 323) power loss problems.
I picked this car up for $600 in a pinch (in the winter of course, and it's a convertible), and it was a great runner aside from a leaking tranny and small slip occasionally going from 2nd to 3rd (like not bad at all yet). I drove it about six months before the timing belt snapped. I must say VERY occasionally it would die at idle like it is now, but it never lacked for power.
So it sat for like 9 months, I ended up draining the tank for my other car (yes I ran the starter to pump out last of gas BAD me!), but then I fixed the belt and it seemed to run fine once I cleaned the corrosion from the battery terminals, but then it just will die at idle periodically and feel like it lost most of it's spark (or more likely fuel pressure drops too much IMO), but then it comes back, like msot of the time it runs fine, then it wants to die and has no power for a second or two, then power comes back. If you goose the gas when it happens you can usually get it not to die before power comes back.
My guess is it is a fuel pressure drop. The system seems simple and I put everything back as it was after getting the gas all out, but perhaps a faulty component (filter, pressure regulator, MAF, ?!?), though I suppose water in the electrics is possible (Washington state, high humidity and lots of rain, and it has sat with hood open), but I have no code scanner (May buy one next month though). No check engine light ever came on though, so I suspect a code scanner, especially considering that it's the older less reliable OBD1, may not solve the mystery anyway.
Sorry for the long post, but this car is quite rare, and finding Mercury enthusiasts to answer questions has been fruitless. It is essentially a 323's DOHC 1.6l with an Auto tranny, no Turbo. Any help is appreciated, thanks!
Edit: IDK if it's important, or any different from a proper 323, but with the Mercury, the fuel filter is in the engine bay (THANK GOD), rather than the fuel tank, so I can't afford a new one today, but it's an EASY fix.
Last edited by Mark J Sherrell; Sep 22, 2019 at 09:30 AM. Reason: To add in details about fuel filter
saiph
Aug 16, 2018 12:21 PM
chrisheyen
Dec 28, 2010 09:59 PM
fordarama@hotmail.com
Aug 16, 2010 05:54 AM
MysteryManInABox
Aug 27, 2007 08:59 AM
alfunt
Jan 30, 2006 10:03 PM
