1993 929 Won't start
Old May 2, 2006 | 12:01 PM
Hallito's Avatar
Default 1993 929 Won't start
I am having problems with my '93 929. The starter cranks fine and so does the engine. But the car won't start. After I crank it several times I get a gas smell. Please help.
Old May 2, 2006 | 11:00 PM
babyhuey's Avatar
Default RE: 1993 929 Won't start
Where are you smelling the fuel odor from Hallito? Stronger under the hood or at rear near the tailpipe or elsewhere? Have you checked to see if you have ignition spark. Do not of course check for spark if the fuel leak is in engine compartment or the no start will be the least of your worries[sm=badbadbad.gif] Did this no start just happen out of the blue or has there been other symptoms of engine hard to start, not running well, recent repair work done?
Old May 9, 2006 | 02:12 PM
Hallito's Avatar
I changed the battery and the problem was fixed. Apparently it was a voltage problem. The gas smell came from the exhaust system it apparently was unburned fuel.
waveslider2007
May 15, 2006 11:34 AM
ryanjaggard
May 14, 2006 04:01 PM
223355rojo
Feb 21, 2006 04:30 PM
Revalve
Oct 2, 2005 04:50 PM
929woes
12
Sep 13, 2005 10:24 PM
