1993 929 Won't start
I am having problems with my '93 929. The starter cranks fine and so does the engine. But the car won't start. After I crank it several times I get a gas smell. Please help.
RE: 1993 929 Won't start
Where are you smelling the fuel odor from Hallito? Stronger under the hood or at rear near the tailpipe or elsewhere? Have you checked to see if you have ignition spark. Do not of course check for spark if the fuel leak is in engine compartment or the no start will be the least of your worries[sm=badbadbad.gif] Did this no start just happen out of the blue or has there been other symptoms of engine hard to start, not running well, recent repair work done?
I changed the battery and the problem was fixed. Apparently it was a voltage problem. The gas smell came from the exhaust system it apparently was unburned fuel.
