Weird a/c noise, only in D
Old Apr 17, 2010 | 07:27 PM
G Bart's Avatar
Default Weird a/c noise, only in D
2004 '3, 160km, great little car (except for the typical Mazda rust problem). Okay, here's an odd one.When the compressor kicks in, there's a buzzing sound -- as if there's something caught in a cog somewhere, or a belt's teeth riding against plastic. The buzz rises and falls in pitch with tach revs...but here's the odd part...it only does this in Drive. Not in Park, not in Neutral.
I've got under there with my flashlight, but can't see anything unusual. Anyone heard of this before? I hope I don't have a major bearing problem...
Thanks!
Old Apr 19, 2010 | 07:51 AM
G Bart's Avatar
Default Re: weird a/c noise
Thanks elmerkit, much obliged. Tension seems okay, so I guess I'll have a bit of wrench work to check the idler bearing. Hope that's all it is...the way my luck runs, if there's 10 possible things to go wrong, mine will be the most expensive to fix.
Mazdaprotege99
Jun 3, 2010 12:50 AM
sly2dabonez
Jan 17, 2008 04:36 PM
leftygolfguy
Nov 30, 2007 08:55 AM
mazda boy
May 15, 2007 12:19 AM
Djshakes
Oct 3, 2005 06:30 PM
