Tire size question
Old Jun 5, 2020 | 11:01 AM
Ricks02's Avatar
Default Tire size question
My car: '02 Protege5
Stock tire size: 195/50r/16
Looking at 205/55r/16
Will these fit and work OK or are they too tall?
Old Jun 5, 2020 | 12:47 PM
shipo's Avatar
They will "work", but as mentioned above, your speedometer and odometer will both underreport your speed and distance traveled. If you want a wider tire which is the same diameter as the OEM rubber for your car you should probably consider 215/45 R16 tires; they are virtually the same diameter as the OEM rubber (they're just 0.185" smaller in diameter).
Old Jun 5, 2020 | 12:54 PM
Ricks02's Avatar
I know where you're going with this and I agree but I am looking at a set of used studded snow tires. Just trying to get ahead of the game.
Old Jun 5, 2020 | 02:12 PM
shipo's Avatar
I assume you're going to stay with the 195/50 R16 size for the winter set and use the others for non-winter use.
Old Jun 5, 2020 | 02:20 PM
Ricks02's Avatar
The other way around. My 195's are almost new. The snows are what I'm thinking about getting.
Old Jun 5, 2020 | 02:40 PM
shipo's Avatar
Bad idea, you want snows to be as narrow as possible; in your case, buy them the same size as your other tires.
Old Jun 5, 2020 | 02:50 PM
Ricks02's Avatar
That makes sense.
RMarkus
Jul 4, 2023 10:08 PM
Taz 454
Suspension
Dec 1, 2015 09:45 AM
staspmr
Apr 1, 2011 11:36 PM
kfx4001442
Mar 28, 2008 05:00 PM
stan2005
May 2, 2006 12:31 AM
