Timing specs and procedure 95 929?
Old Jun 17, 2007 | 10:20 AM
tigrmiller's Avatar
Default Timing specs and procedure 95 929?
What is the timing supposed to be on 95 929 and aside from hooking the light up to #1 plug wire is there anything else that needs to be done. I read something about having to ground some wire on the diagnostic plug? Is that necessary and what does it do? How accurate does it have to be set? Doesn't the ECU constantly adjust the timing? Thanks
Old Jun 19, 2007 | 08:31 AM
Sirob's Avatar
Default RE: Timing specs and procedure 95 929?
Tigrmiller, try this http://929.sentia.ru/english.htm
Old Jun 19, 2007 | 12:57 PM
tigrmiller's Avatar
Was unable to access info at that site without purchasing and downloading additional software. Any other ideas? Surely someone on this board mustknow what the timing is supposed to set at. thanks
Old Jun 21, 2007 | 07:23 PM
babyhuey's Avatar
Need to get engine to operating temperature and then ground the TEN pin of the diagnostic tester as shown in the diagram below. Grounding the pin takes PCM control out so that base ignition timing can be set. Without the pin grounded you should be seeing timing between 7-20 'BTDC. Once the TEN pin has been grounded and computer control removed base timing should be at 12 'BTDC +- 1' or 11-13 BTDC. While the TEN pin is grounded go ahead and check base idle speed as well. Should be 700rpm.
[IMG]local://upfiles/1377/B1C91606D75E484FBA1F324A371831B0.gif[/IMG]
kavee
Feb 6, 2011 09:14 PM
swoop4321
May 30, 2010 10:24 AM
tigrmiller
Jun 17, 2007 10:22 AM
hiliftjack
Mar 3, 2007 11:05 AM
Roleary
Apr 25, 2006 10:20 PM
